Orange buffer pads???
Mr Monk
Would the use of an orange buffer pad (from CMA) be ok to use on a PC with 3M IMG to remove fine line scratches? Would it be too abrasive on clear coat?
Thanks!
It is best to try the least aggressive approach first, try using the IMG with a white pad first, if you don't get results then go with the orange (maybe even yellow).
As for the IMG itself, I assume its like PI III MG; I got no damage using it even with the orange and yellow pads
