Optimum Polish and sonus swirlbuster pad
galerie
Has anyone used Optium polish with the swirlbuster pad. i was wondering what the outcome was. i just purchased the polish and want to know what is the best pad to apply this with
No sense "Busting Swirls" with that pad when you're only using Optimum Polish (OP). OP is a finishing polish, designed to make a "Swirl Busted" finish look deep and wet.
SwirlBusting requires a SwirlBuster type pad (Yellow, Orange), and be used with either Optimum Compound (OC), or Optimum Hyper Compound (OHC).
Then OC or OHC with OP on a white polishing pad, and you'll be amazed with the results :getdown
Just did a '98 Black Accord Coupe with a lot of swirls and rotary marks. I used OP with a white polishing pad and was very pleased with the results. So was the owner. Followed the OP with AIO and UPP.
