Opti-Seal and Duragloss - Is there a point to using AW when using OS?
Paulie Walnuts
So I would like to try out both the Duragloss line and Opti-Seal.
The process I was thinking was
Prime Strong
DG 105
OS
AW as a booster spray as needed.
Is there a point to using AW or is OS pretty much the LSP in this process? Should I even use the DG 105 or is OS all thats really needed for a good protection?
Thanks!
I just tried OS over 105 & AW and can't tell much difference on a light colored car.
I can't say if OS alone will look as good as 105 + AW though. With the little playing around I have done, I can tell you that OS alone seems to add more gloss and wetness than AW alone.
use it like you said, as a topper. AW looked stunning over Z-CS, I bet it will do the same over OS, plus it will keep it going and going and going.
WilliamHBonney said:
S
Thanks!
That's hard to say, as it's undetermined how protective and durable that OS really is. Personally, I would go with 105 and OS, but that's me. Also, I would not use AW if you are using OS as the last step so as to judge OS durability, looks, etc... OS "should" have greater durability to AW (which would negate needing to use AW), but we'll see.
