Jean-Claude
Keeper of the beautiful
I've had Flyby30 installed on my truck since 1/15/13 and just received a sample of the Opti-Glass coating. I decided to do a head to head comparo. The passenger side has flyby30 installed and the driver side now has Opti-Glass. The Flyby30 has a 7 day advance on installation and should be noted moving forward.
The Opti-Glass has a different application process. Like Opti-Guard, it has a very limited work time. Opti-Guard gives us about 5 minutes after applying before requiring leveling/dry buffing. Opti-Glass has 60 seconds before you must buff off the residue. It was emphasized that you really don't want to leave it on too long. My plan was to work in smaller areas so that there was not an opportunity for it to set up too fast.
Full disclosure: I applied 2 coats of the flyby30 and did the same with the Opti-Glass. What you're seeing in the video is the second application. Though, it applied the same the first time around.
My process for the application was to tape off one side and remove the flyby30 from one of the sides. I used polish and a microfiber towel to remove the flyby30 and followed up with an IPA wipedown. I spritzed water on both sides and confirmed that all of the flyby30 was removed from the side the Opti-Glass went on. While the side with the flyby30 had water beading, the other side showed signs of absolutely no coatings. The water sat all nice and ugly like you're used to on untreated glass.
I believe a major factor to consider will be the cost. Carpro's flyby30 is supposed to last 6~9 months and if I heard correct, Opti-Glass is more of a 2~3 year coating. We will have to see where the Opti-Glass lands price-wise before the professional detailer sees how it fits into his services. **edit** Retail version will be $79.99 and will be advertised to last up to 1 year. The professional-only version will last up to 3 years at a cost of $100. Both will come in 60ml syringes.**edit**
The video of the application: https://www.youtube.com/watch?v=ftDdO51wYr0&feature=youtu.be
I will follow up with more information as it becomes available during the comparo.
Follow up: http://www.autopia.org/forum/car-de...-www-detaileddesignsauto-com.html#post1535276
