Hmm… I dunno. Correct me if I’m wrong, but I believe all this can be categorized into three groups: Chemical cleaner, abrasive cleaner, and physical cleaner.
I like to define chemical cleaners such as Klasse AIO as using its own solvents to chemically loosen the bond of the contaminates. The only abrasive action is the heat generated from the applicator or anything in between the paint and the applicator. Think…if you lightly spread a thin layer of AIO on the paint, and wipe it off, there will be minimal difference. But if you use a Microfiber applicator with firm pressure, like you’re “working-it-in,â€� you will see a greater cleansing effect from the different application technique.
As with an “abrasiveâ€� cleaner, I like to think of it as liquid sandpaper. Such a product usually contains a coarse element inside to removes a thin layer of paint… leveling out the swirls. An “abrasiveâ€� is more like 3M SMR, rather than AIO whose solvents depend on your force.
For a physical cleaner, such as clay, force still needs to be exerted (like chemical cleaners.) However, instead of depending on powerful solvents, contaminates stick to the bar, pulling everything off. This is definitely not liquid sandpaper. <em class='bbc'>However[/i], some people consider the friction and stuff stuck on the clay to be causing some harm and <em class='bbc'>“abrading�[/i] the paint from the contaminates on the bar...... but the damage is <strong class='bbc'>very[/b] minimal if you use a lubricant and fold it multiple times. I wouldn’t worry about it.
Also, the definition of “abrasiveâ€� can be different for each person… leading to this confusion. Some may consider anything to smoothen the paint abrasive, yet some may say that anything with something coarse inside is (like SMR.) Or same with getting contaminates stuck between the clay and paint. Do you consider that abrasive? Then is getting keyed “abrasive?â€�
All in all, I would probably make your own conclusion as there is always more than one answer for every question. Ones definition of abrasive may be different from someone elses. Isn’t free speech and this forum such a great thing?
~bw
