wendell jarvis
What is a safe dilution ratio to clean Leather with OPC ?
It's safe straight or diluted. It does need to be followed with a damp cloth to remove any remaining residue that might turn white if allowed to dry. The stronger you mix it, the more I'd recommend applying it to the applicator and not spraying it on the surface. Not because it's unsafe, but because the runs will cut through the dirt faster and those runs will take time to match with continued cleaning.
I start at 3:1 and if it's not fast enough, I make some stronger. I don't mix it any weaker because I keep Opti Clean handy for light interior cleaning...and it doesn't need to be followed. I usually use Power Clean on the heavy soils, then wipe the whole interior with Opti Clean.
