OP Spray gun....
mose
Was thinking about trying just a regular paint gun with my compressor instead of the OP Spray Gun....Has anyone used this item or used anything else that worked? This is to apply the Opti Bond Tire Gel........Thanks!!
The Optimum spray gun is a suction gun. The one most use with compressed air is gravity fed.
You can pick up one at Harbor Freight for around $15.00
I'm an addict for the Wagner. I bought several of the nozzle/tank combo kits that just snap into the turbine. I use it for Optibond, Best Dressed, PowerClean, Instant Detailer, Optimum Spray Wax and anything else I need to. After adjusting the trigger and nozzle position to your liking, you never have to set them again.
I stand corrected. The gun on autogeek is the one being spoken of:
autogeek_1999_53337894
However I was refering to this gun on KleenCar which is gravity fed. I though that this gun had the "Optimum" name also, but it does not.
