4u2nvinmtl
I tried the Rinseless/Waterless wash method using 10 towels in a bucket with ~2 gallons of water and ONR, for the first time this past weekend.
Pros:
· Uses less water
· Car is just a clean as two bucket wash
· Less water to dry (less water in the cracks)
Cons:
· Lots of dirty towels
· Took long as a two bucket wash
· Little to no advantage over two bucket wash
I had detailed (two bucket wash) my car 3 days earlier and I garage it so I figured this would be a good test for ONR. I started by washing the wheels with two buckets, then I did the engine bay (degreaser/APC, flood rinse, Duragloss dressing), while the 10 borderless towels (from chemical guys) soaked in the ONR solution (3-4 caps of ONR with 2-3 gallons of water). I took the first towel folded it in four and started with the roof. I did smooth long wipes trying to adjust the edge (part of the towel) making contact with the paint by turning my wrist and then flipped to a new side after every wipe. The towel floated over the paint on a cushion of ONR solution and absorbed all the dirt suspended in the solution very well. To my surprise the roof was much dirtier than I anticipated, so I clayed it for the second time ever and topped it with some Collinite 845.
I couldn't’t help but notice how dirty my white borderless towels were getting with this wash process but figured I can’t stop now so I did the whole Jeep panel by panel (drying as I went). I also noticed my waffle weave towels were picking up dirt suspended in the left over ONR when drying. When I was done I was surprised how good the Jeep looked, I wish I could say the same for the 10 microfibers and the 3 waffle weave towels. After washing the towels (separately) the waffle weave came out as good as new but the 10 borderless towels are still dirty looking (washed them again and they still don’t look white).
All and all it wasn't’t any faster than my typical two bucket wash and it took much longer to wash all the towels (10x borderless towels washed twice, 3x waffle weave washed once in separate load, folded and stored in Ziploc bags) compared to a two bucket wash (2x mitts washed by hand, 3x waffle weave in one wash load, folded and stored in Ziploc bags). I also must admit that there were no visible scratches induced using this wash technique. I probably won’t be doing another Rinseless/Waterless wash unless I’m somewhere where there’s no access to water (car show or something), but I will be using/testing ONR as a clay lube, quick detailer, and additive to my car wash soap solution.
It’s too soon to say if I liked ONR more or less than UWWP as they are very similar. The only comparison I can make is that the ONR didn't streak as much as UWWP when wiping it off the paint.
Update with recommendations/comments/suggestions:
#1 - Wash it to Accumulator/Autopia standards by doing multiple cleaning passes, confirmation will be a clean drying towel
#2 - ONR in a spray bottle at a higher concentration and a couple of wash pads in a water bucket
#3 - Two buckets,one with ONR, one water, and some wash pads
#4 - (mix and match) Spray it down with UWWP then using two buckets, one with ONR, one water, and a couple wash pads
Thanks everyone for the recommendations!
Pros:
· Uses less water
Cons:
