ONR QD streaking
99blackSE
Okay so I mixed up some ONR to QD specs in a old Megs QD bottle. It was working fine and dandy, until the last couple times, where it has been leaving streaks, that can only be seen in a certain angle of sight, but are quite noticeable.
What would cause this?
I washed out the bottle and trigger system thoroughly before mixing the ONR in there. What I think may be the culprit is that I am almost empty of the bottle and the ONR may have settled and is not mixed with the water properly anymore? Would shaking it a bit before using it solve this problem? Or it would be an improper mix ratio?
Thanks for the help.
