ONR clay lube ratios for smaller bottle
I came out with:
*64 oucnes of Meguiars car wash (only 2.99!)
*Eagle One A to Z cleaner (you guys say it's good so what the heck)
*Never dull
*Meguiars glaze
Not that much but the point on it all, good thing CMA doesn't have a store around here, I'd buy stock if I knew I would be doing some spending.
It's not the Gold stuff (I wish it was). It was an AutoZone is Dorchester.
P.S. I know it's not the Deep Crystal stuff either ........ jeepers, what the heck did I buy.
Jeff-
If there's a Target near you, you can pick up Meguiar's GC there - they normally charge around $8.99 for one gallon.
JohnN, where is a Target in the NY area ? Got the windows tinted last week at Professional Window Tint in BKLYN . They did a great job. Thanks again...........Syker:up
I went to K-mart today (after going to the NY DMV.) Looked around the car care section adn saw some interesting product. TW tire wax 16 oz. with applicator $5.49 (passed on that.) 3M auto carpet + upholstry protectant (passed on that too.) Everything else was pretty much a waste.
I saw the Armour All cleaner and protectant, I think Clean Dean uses it. It has a blue colored coded trigger.
Jason
EDIT. Joed1228, was the wash blue or pink?
Syker-
I go to the one in Queens (College Point) because I'm out there quite a bit - but there's a couple of Targets in Jersey - check out the maps here.
Can't really blame CMA for the pricing on the 16 ounce bottle - that's pretty much the price for it at any auto store. That's why buying in bulk ROCKS.
Heheh, I went to an Autozone yesterday and came out with a tube of Scratch-X, 3 Viking 100% cotton wash mitts, Eagle One QD, and another Viking foam applicator.
Hey, I was just looking... :D
I know a lot of guys on here are using ONR as a clay lube and Im wanting to use it also, but the problem is I dont use enough to make a gallons worth. Does anyone mix it in a 16 or 32 oz bottle? If so what are your ratios? Thanks
I use smaller bottles. Its the same ratio for a gallon. Just adjust for the current oz bottle used.
Sent from my HTC Vision using Tapatalk
1/2 ounce per 32 ounces I think would be right........ at the suggested dilution rate of 2 ounces per gallon of water.
I found that at that rate though was not slick enough for the clay bars I use,so you may add a little more to your liking.
