I am so happy to see an actual
Lake Country HydroTech/Shred Appreciation Thread !
Had used Lake Country
Flat Pads for years before, and while they were ok, until they came out with the killer - Purple Foam Wool, it was slow going on hard paint, hard correction jobs.. They only went up to a yellow pad and it was not that great..
The initial Hydro`s were having much issue with the velcro backing cloth coming off for sure first time you washed them, and then they did not really like anything at high/hot speeds/temps...
I personally sent a Lot of them back and the great people replaced them for me.. I really appreciated that the Forum Stores took care of us who blew these pads up for a while...
After so long, everyone just acted like they didn`t exist, and that was really too bad, because they really are a very good pad group and it`s only 3...
Along the way I gave them the new name - Hydro-Shreds - and it appears to have been accepted by many..
For any type of paint, with any compound, I have never had a bad experience with the workhorse - Cyan - and the total thoroughbred - Tangerine -
And if you are really wanting to amp it up even more, the Crimson is pretty darn hard to beat...
Lots of people used to use the Crimson with a good Glaze, etc., at the end to really pop the paint even more..
These pads flat
work and with a Rotary and a lot of pressure if needed at slower speeds; you take care of the heat issue because of the lower speed, and Still get incredible correction if you want to take the time to let your product just about go completely away from the paintwork...
And of course, the Cyan and Tangerine always - always - finish down beautifully.. I never have to go back with yet another color pad to clean up what the last pad did to the paintwork...
For my process I always keep the pad surface just moist enough to avoid any sling issues, to allow the product, pad and surface to get to know each other very well..
All of the Menzerna line of compounds and polishes, the Optimum line and the Meguiars line work just fine with the Hydro-Shred pads and I have never had a problem on any hard, medium, or soft finicky paintwork using these pads..
Glad to hear that some have found they work great with the HD line of compounds/polishes too..
I just hope every year, that they continue to make them..
Dan F
