OC and OP Mix?
fdizzle
Looking for homegrown recipies for the optimum line
mixes with:
OHC and OC
OC and OP
anyone use blends?
effective mix ratio?
benefits of mixing these vs individual application?
hit me up . . thanks folks . . :think2
I some times blend OHC and SSR3 for some extra cut. I guess you could blend OP and SSR2.5 as well. OC and SSR2.5 are pretty close in abbrassiveness so no blending there. You could add OP to any of the SSR line to cut down the dusting :think: , I think I will try that.
I recently got to try out a mixture I made out of curiosity. I mixed about 40% OHC in with 60% OP and ended up with a product that gave a little bit more bite than straight OP but didn't leave the marring OHC usually leaves behind.
I used an LC Orange with the mixture and had an LSP ready finish in one-step on a lightly-swirled car. It wasn't near as aggressive as OHC, some areas needed a second pass upon close inspection, but it definitely had a fair amount more bite than I usually get with OP. It also didn't clog up the pad near as bad as straight OHC.
