nonsensez9
....a whole lot better. Plus lessons learned from 1st time PC use
suggestions welcomed
process
wash
clay
PC with M83 and Orange 6.5 inch pad (some areas 2 times)
PC with M80 and White 6.5 inch pad
PC with Blackfire Gloss Enhancing Polish and Black 6.5 inch pad
hand applied PolyCharged Blackfire All Finish Paint Protection (two times)
before(1)
before(2)
before(3)
after(1)
after(2) - notice I did/could not buff all the sealant off the hood
after(3)
after
lessons learned
(1) M83 dries quickly and is hard to buff off - must investigate other products
(2) smaller pads and backing plate would probably have yielded better results
(3) saturated pads are not as effective, must get more pads
(4) M80 is much nicer to work with than 83, and it removes residual 83 that could not be easily buffed off
(5) Polycharged BF is a bugguh to buff off when left to bake in direct sunlight - see after photo 2 - must look into Zaino Clear Seal. Perhaps a microfiber bonnet on PC would have worked.
(6) without fail, rain will fall within 2 days
process
wash
clay
before(1)
before(2)
before(3)
after(1)
after(3)
after
lessons learned
