Nice deal on a Honda Powered Pressure washer -$170
Dan
Well-known member
Yeah, its probably not that great of a pump or honda motor, but it beats something you'll find at HD or Lowes.
Factory Reconditioned Simpson MSV2700R 2,700 PSI MegaShot Premium Residential Gas Pressure Washer
Honda GCV190 OHC Engine for easy starts and proven reliability
Direct drive engine and pump for streamlined power transmission from the engine to the pump
Welded construction with 1-1/4-in tubular steel with 12 gauge steel engine plate and solid steel 5/8-in axle
Unloader system with thermal relief valve
10-in pneumatic, double-sealed tires easily take on tough terrain
Includes:
2,700 PSI MegaShot Premium Residential Gas Pressure Washer - MSV2700R
1/4-in x 25-ft Hose with Easy Connectors
(4) Quick Connect Nozzles
Detergent Siphoning Tube
Spray Wand
