fins&chrome said:
My other challenge is that the sheetmetal on these classics offers many obstacles such as curves, ridges, dips and curves everywhere...so I guess 4” pads would come in handy for those situations....and I’m not even talking about the chrome pieces which I’ll have to mask off properly.
My favorite body styles to buff out are the classics, compared to many, (not all), but many new cars the classics have much larger and smoother and even flatter panels. Compare the panels on a 1952 Chevy Belair to a Hummer.
Can we ask what it is you're specifically working on?
Accumulator said:
A pal of mine cut through the clear on her Benz using one of my PCs and a Meg's 7006 pad so the big pads sure must do *something*! BTW, as Mike Phillips was there when that happened, I've always wondered if her "oops!" was responsible for the Meguiar's admonition to not use 7006 pads via PC :think:
Hi Accumulator,
I must have buffed out too many cars in my life as I can't seem to remember this oops as there's been plenty. :nervous:
Regardless that incident had nothing to do with Meguiar's recommendation to no use their foam cutting pads with dual action polishers, it really just has to do with the fact that if a person isn't experienced with a PC and they use a cutting pad and haze their car's clear coat they won't know what to do and might panic instead of either adjusting their pad or chemical choice and/or plan on re-polishing the paint with a less aggressive product to remove the haze. Kind of the better safe than sorry approach.
The recommendation for the new W-7207 foam cutting pads is Meguiar's doesn't recommend them with PC style polishers but if you are going to use one then do a Test Spot first to see how the paint you're polishing is reacting to it before going over the entire car.
The foam formula for the new washable W-7207 foam cutting pads is different and less aggressive than the foam formula for both the W-8000 and the W-8006 pads and I've found it to work really well most of the time. As a long time habit though, if I've never worked on the car before then I always test first.
Accumulator said:
IME the ~6" pads don't cut period. Too much friction, my PCs just "jiggle" with those pads.
While I agree a smaller pad will always rotate better I've buffed out a ton of cars using 6" pads on PC.
Last night I tried out the new PC 7424XP and I was very impressed with the tool. I was using the 6.5 LC Orange and White pads on a Tahoe and as long as I held the pads flat to the panel there was no problem at all keeping the pads rotating.
I'm going to buff out a black Lexus all day tomorrow and will play with it and the Flex XC3401. Seems everyday if I leave my chair new things to test somehow appear on my desk?
Flex XC3401, PC 7424XP, Flex 3403, the new Dodo Juice Supernatural Wash Mitt aka Wookie's Fist, Dodo Juice Supernatural Shampoo, Dodo Juice Austintacious Soft Wax, and the new LC Gold Foam Ultra Finishing Pad appeared out of nowhere after lunch!
:woohoo:
Accumulator said:
I prefer to only advocate approaches that have worked well for me.
Them be words of wisdom right there...
Accumulator said:
I was approaching this a little differently than most cars, and wasn't even thinking about the M105/M205 twins.
Rather, I was thinking about a "less than perfection, but still very nice" goal using M80 for most of the polishing (maybe all of it).
M80 is a tried and true winner for single stage paints, especially antique, original or neglected single stage paints. After the M80 maybe some M205 or stick with the TS oil polishes like M82 or M09 for a follow-up pass. Could be M80 will get the paint to where you want it without the need for a second polishing step.
Do a Test Spot first and let the results of your test spot be your guide.
Accumulator said:
Also, it's simply different from the Meguiar's offerings in that it doesn't contain the Meguiar's Trade Secret Oils, which I simply *love* on single stage.
I agree. The TS oils Meguiar's has been using since their inception do work really well on single stage paints to really bring out the full richness of color.
Then top with your favorite wax or paint sealant and after that it will be time to take your 50's cruiser for a cruise.
:2thumbs:
