Hello all! I'm a long time lurker around this forum.
I have wanted to Opticoat my car for a while now and finally found the time to take on the project this past weekend. I have never actually polished before, but have read up extensively on the topic on the forum and watching videos. When I got to the polishing step, I followed all the instructions I read and watched, but have had a hard time getting results on my test panel. I am wondering if you folks could take a look at my process and offer some tips. Details:
My car has light swirl marks and just a few bigger defects. I am not looking for perfection, I just want it to be pretty good before I coat it.
My products are Optimum Polish II, Optimum Finish, and the Harbor Freight DA polisher.
Of all the reviews I have read about Optimum Polish, I feel a white pad and the polish should be perfect for light polishing. Only need to step up to a higher pad for serious correction.
My plan was to use white pads and Optimum Polish II and then finish with blue pads and Optimum Finish.
I primed the pads, put three dollops of polish on the pads, and attempted ta 2x2 section... nothing. My method was to spread the product, then go over it about 6 times (and holding the polisher down with some pressure. Didn't seem to effect the imperfections at all. Admittedly, on my first attempt I was probably moving the polisher too fast. But I retried a couple times. Finally, I tried the one orange pad I have and still no effect on the first try. On the second try I really held the polisher down with a lot of force and did about 8 to 10 passes. Finally I saw some reduction in swirls... but the pad looks to be coming apart.
I knew it wouldn't be perfect right from the get go... but I get the impression I should have seen some results much easier than this. The only thing I can think of is I put opti seal on in October to give the car protection for the whole winter.But it has been 6 months since, so I figured that should have worn off by now. If it is the Opti-Seal that is making it this hard, will Dawn or Eraser remove it?
Note... I am on a budget, so would really like to figure this out with the tools I have on hand. I also would like to take the least aggressive approach that gets me results.
