Vinyl is a plastic made from polyvinyl chloride (PVC) with a chemical polymer plasticizer mixed in and it’s also an ultra violet (UV) sensitive material, which degrades when exposed to sunlight. Maintaining the integrity of the topcoat and protecting against UV damage are the keys to keeping vinyl looking and performing "like new".
ValuGuard Exterior Trim Repair Kit (ETR) - solves the stubborn problem of "gray bloom" sun fading and wax/polish residue on black trim components.
The seals around the vehicles lights (headlights, brake and indicator lights, etc) and the soft seals around doors, windows, sunroof’s, hood and trunk are constantly being flexed and compressed all the while being subjected to a hostile environment. For maintenance use a product that contains glycerine to maintain the look and feel of the material
Periodically clean using Iz einszett 'Plastik-Reiniger' an intensive, non-corrosive, non-acidic two-phase deep cleaner for that removes grime build-up thoroughly and effortlessly, these chemicals restore the original texture, tactile feel and resiliency
Protection – using 1z einszett Vinyl Rubber Care & Potectant "Tiefenpfleger” for use on clean or pre-cleaned vinyl or rubber, it provides a temperature-resistant seal and a low-shine matte finish Dust-resistant and retards the fading effects of UV rays to keep exterior ‘rubber’ and vinyl looking like new.
Ultra violet (UV) protection is a sacrificial / renewable component; this is due to the UV protection layer being degraded by exposure to the elements (sun, sand, road or sea salt, and etc) so it is imperative that you renew it and needs to be re-applied on a regular basis (dependent upon location climatic condition)
Alternative products- 1z einszett Gummi-Pflege for use on clean or pre-cleaned rubber, protection and durability measured in months, it has a little sponge on top of the bottle so you always get the right amount of product on your weather-stripping or rubber seals. Once applied to rubber they will take on a dark but natural shine. Use bi-annually to provide protection to avoid rubber from hardening or freezing.
