imported_Grouse
I have rented one 3-4 times now. I'm sick of making the drive. so i picked up an Ozone machine, and a couple of air movers. I picked up the air movers to promote drying with in the car. I want to get it dry faster than it is currently taking.
AC082 - AIR KING PLUS AIR KING PLUS Item No.
AC082
Pivoting Utility Blower
The Air King Plus is 50% bigger and moves 50% more air than the standard Air King Blower (AC081)!
Each unit draws only 1.0 amps on High setting. One 15 amp circuit will run 15 to 18 blowers! Simply plug one blower into the wall, then string more blowers - one plugged into another!
● Maximum air velocity! Air King is still pushing air 50 feet from the unit!
● Direct air where needed with an infinite number of blower head positions
● Speed dry upholstery and carpet after cleaning or when spotting
● Flash dry hard surfaces after cleaning and mopping, or when applying floor finishes
● Use to cool you while working in the heat
● Plug other electrical tools directly into the Air King
● Flood restoration! Low amps+high air velocity+small size = quick structural drying!
● Rugged, easy to carry handle
and this
The Oasis Plus
Ozone Generator
The new Oasis Plus performance improvements include the addition of a hermetically sealed severe application transformer designed specifically for harsh electrical and environmental demands imposed by continuous-duty corona discharge ozone generation.
The transformer is a recognized UL & CSA component. Because of its durability the warranty on the transformer has been increased to three years.
Ozone is the strongest oxidant commercially available and is a proven deodorizer. The Oasis Plus doesn't just cover up foul odors; it actually destroys the molecules that cause them.
Click Here for Specifications
Oasis Plus has a patented high-density ceramic and stainless steel electrode corona discharge system, manufactured with stainless steel probes encased in ceramic with an outer stainless steel sleeve. No place for dirt or impurities to accumulate. They are maintenance free and are guaranteed for life. No old fashioned plates to clean or corrode. Let the Oasis Plus clear the air for you.
Applications:
* Fire restoration; smoke elimination, removes mold, mildew and other organic odors
* Quickly deodorizes hotel/motel, hospital and meeting rooms
* Excellent for freshening up cars, buses, boats and aircraft
Contact U.S. Products today for more information on the Oasis Plus ozone generator.
8)![]()
