imported_RedlineIRL
I am about to use the Optimum Compound II with a PC 7424, non XP, and LC 5.5" orange pads soon, and I had a few questions before jumping into it and wasting tons of time trying to figure it out without any know how. So I am hoping that any of you all that have worked with this product could give me a few tips on it
From what I have heard the Optimum Compound II is similar to the Meguiars SMAT technology, meaning that the abarasives are non diminishing and keep working. Is this true? If so, how can you really tell that the product is ready to be wiped off?
When using this product with the 7424, what is a good range to use as far as speeds? I'd imagine that using speeds 5-6 is optimal, but what about before finishing? Should I reduce the speed to 4 or so along with the pressure on the machine? Or will this make a difference with it at all?
How should I prime the pad with this product? Lightly spearad it over the pad surface like M105, most the pad with ONR QD strngth mix and apply an X or couple dime sized drops? I don't want to over apply and end up reducing the cut along with clogging up the pads
Do you all find that Optimum Compound II creates a lot of hazing, even with a DA such as the 7424? I went ahead and bought some of the Polish II just inase. Thanks for any answers that you all can help me with
