If I chose that route and used m205 then I would use a black pad since i already took care of the swirls with the d300. Since using m205 with orange pad would help remove what was already removed? Another question could I just do step one then use any other type of polish such as deep crystal or etc.. Or even skip the polish stage and just add dfwd?
( I'm new to detailing and do want to go pro so I'm not sure on combos sorry if I sound like a noob)
Just want to thank all of y'all for all the help.
No problem.
Yes, you would follow up D300 with M205 or 106fa on a foam pad like the black LC.
The D301 is meant to kill two birds with one stone by being both a finishing polish and a wax all in one. This is great for high volume shops, client's not wanting perfection, or someone who's simply on a tight budget. It's also great for ones personal car if they want to minimize the time polishing and waxing.
However, if you want the best possible finish with long lasting protection, you will almost always have better results doing each step individually with dedicated products rather then using an all in one (AIO) type of product....at least when there is correction involved.
Which finishing polish and pad combo you use to follow up after the D300 compound will depend on how well it finishes down. On some paints, especially light colors you
could go right to wax (BFWD) if it finished down really well, but you will likely still see an improvement by following it up with a finishing polish first, and that's what I'd suggest doing.
Honestly, I have yet to need anything more than M205 or 106fa on a black or tangerine foam LC pad to follow up with after D300 as it tends to finish down very well on most paints.
Hope that clears up what I was trying to say.
Rasky
