Sparky123- OK, I'm not familiar with that polisher, but I'll assume (uh-oh...) that it's up to spinning the 6" pads. FWIW, I *never* touch either of my rotaries these days. Never. No need for them with today's pad/product tech.
I never had huge dust problems with M105 the way some people do...maybe because I don't "work it until dry". But you do have to use a lot of product and that can get messy. I work pretty small areas at a time, and IMO that helps keep everything under control, including the mess.
Pace yourself, take it slow. Keep the areas of operation small; I seldom do the usual 2' x 2' that people recommend.
DO NOT let the product get dry on the pads and DO NOT let the pads get loaded up before you clean/replace them. That's just *so* important.
I seldom wash after compoundinging, in part because that can get compound residue down into nooks and crannies (carried there by the water/washing). IMO it's better to do a lot of masking before you compound to keep the stuff out of hard-to-access areas. Yeah, that can take a lot of time and effort (BTW, I like the newer *yellow* masking tape). I use M34 Final Inspection when buffing off M105 residue to minimize micromarring.
Research the Kevin Brown Method for info on how to prime your pads for use with M105/M205.
Rather than using IPA for removing polishing oils, I use Akra Klean (think that's the name/spelling, it's AKA Prep Wash) from Top of the Line. Many use a product called Eraser. Sorry, I can't do links on this computer/site for some reason, but you should be able to google 'em up.
Make sure the garage has the *right kind of* light; fluorescents are basically useless IMO.
