AutopiaTech
Moderator
Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pads make it easy to polish your paint to an award-winning shine! This is because Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pads are constructed of high-quality German foam formulas and designed with unique features that deliver maximum results. Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pads run cool, reduce effort, eliminate pad hop, and deliver consistent results on dual action and rotary polishers.
A grid pattern of channels cover the face of each Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pad. These channels increase the airflow through the pad when operating at high speeds. The paint remains cooler and the polish performs better. The unique face of the Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pads also improves surface contact when polishing smooth, rounded body panels for consistent results.
When used with a rotary polisher, Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pads eliminate the pad's tendency to hop, skip, or chatter across the surface. Cobra Cross Groove Flex Foam ™ 6.5 Inch Buffing Pads feature a beveled edge that further increases this pads ability to glide over the surface. This smooth buffing action reduces the chances of creating buffer swirl marks known as holograms.
Cobra Cross Groove Flex Foam 6.5 Inch Buffing Pads
