Applying Zanioâ„¢ Sealant 19-6:
Zanio was voted the number one synthetic polymer sealant by an independent testing body (Guru Reports) its application process has a small learning curve, but once mastered the results are well worthwhile. This is the product I use for the preparation of concourse vehicles (or any vehicle that requires a â€Ëœshow carâ€â„¢ shine
Zanio is a synthetic polymer wax, a compromise between a polymer sealant and a natural wax. Use either Z-1 Polish Lokâ„¢ or ZFXâ„¢ accelerator The polymers do not require a lengthy cross-link (cure) time as ZFXâ„¢ is formulated to accelerate the time requirements. Z-2â„¢ or Z-2PROâ„¢ produces the most gloss of the synthetic waxes (although theyâ€â„¢re labelled as polishes) it is more optically clear then Z-5â„¢ and will highlight any surface imperfections, whereas Z-5 will â€Ëœhideâ€â„¢ very
minor surface imperfections with fillers. Z-3â„¢ is a â€Ëœpolishâ€â„¢ for single stage (non-clear coated) paint
a)
Detailers Tips:
1. Apply this product using water-dampened applicator, and then spray the applicator with Z6.
2. Apply Z-solution very thinly using absolute minimum pressure on the applicator.
3. Spray the vehicle surface very lightly with Z6 between each â€Ëœlayerâ€â„¢. I cannot emphasise â€Ëœapply products very sparinglyâ€â„¢ enough.
4. Use Z-5 + ZFX for dark colours Z-2 + ZFX for light colours.
5. Use Souverän Wax as a final product on red, black or Porsche Speed yellow it produces a deep wet shine or Pinnacle Signature Series Wax for metallic and for light coloured vehicle paint
6. The secret to the application of a polymer product is to apply it thin
(super thin) fill a spray bottle and
mist a foam pad for application.
7. Ease of product removal is inversely proportional to the amount used (less product easier removal)
8. If there are places were the wax is thick and you are having trouble buffing the residue, wash affected panel with a Z-7 wash solution.
The brand is named â€ËœShow Carâ€â„¢ as it relies on a very thoroughly prepared paint film surface to produce the best results, the final result can only be as good as the surface itâ€â„¢s applied to.
b)
Surface Preparation-
a) Surface Preparation-
1. Wash vehicle with a good quality car wash concentrate 1.0oz per 2 gallon (Zaino Z-7)
2. Rinse vehicle thoroughly.
3. Remove any imbedded contaminants with detailing clay (Clay Magicâ„¢) and a lubrication solution 5:1 (Distilled water/Woolite®)
a) Remove any surface imperfections with a suitable machine polish
b) A swirl mark remover (3Mâ„¢ PI-III Machine Glaze, P/N 05397)
c) Clean paint film surface with a chemical cleaner / polish (Klasse All-In-One)
4.Lightly wash paint surface with a diluted car wash concentrate (Zaino Z-7) 1.0oz per gallon
5.Dry thoroughly and start the application of Zaino Z-2/ Z2PROâ„¢/Z-3 / Z-5/ + ZFX solution
Application Methodology:
â€Â¢To mix ZFX do not squeeze the bottle, simply hold it horizontally and let a drop dispense, then tip further down again for the next drop and so on
â€Â¢Mix solution (one ounce of Z-5, Z-2 or Z2PROâ„¢ in a mixing bottle, and add 4 or 5 drops of ZFX.
â€Â¢Shake vigorously for one minute and then allow the cure accelerator to activate (about 30 seconds)
â€Â¢There is no need to use ZFX for every application, although using ZFX will give you a brighter and deeper looking finish
â€Â¢Wipe down the entire vehicle with Z-6 using 100% cotton Microfiber towel.
â€Â¢Shake the Z-Solution again for 30 seconds.
â€Â¢Lightly spray a Microfiber applicator with Z-6. You want the pad to be damp, not wet.
â€Â¢Apply to whole vehicle (0.5 â€â€œ 1.0 oz should be sufficient for most vehicles) taking care not to apply to absorbent surfaces (i.e., unpainted plastics and rubber trim)
â€Â¢Lightly spray Z-6 between each coat of Z- solution; check the applicator pad frequently for any contaminants it may have picked up.
â€Â¢First pass: apply (ultra- thin) apply the Z-Solution to the entire vehicle, roof to floor on vertical surfaces (doors, fenders and skirts) and across on horizontal surfaces (roof, hood and trunk)
â€Â¢Second pass (ultra- thin) apply Z-Solution in direction of airflow, horizontal surfaces hood to trunk, vertical surfaces front to back.
â€Â¢Third pass (ultra- thin) and any subsequent layer(s): apply Z-Solution in same â€Ëœdirection of airflowâ€â„¢.
â€Â¢This application technique affects the paints optical properties by optimising light refraction and the reflectivity of the bodylines and contours of the vehicle.
â€Â¢As air is the primary catalyst for the wax to dry, low air temperatures and / or humidity may effect the drying time requirements.
â€Â¢After sufficient drying time do a quick swipe test with your finger. If no smearing or drag is evident, the residue is ready to be removed.
â€Â¢Residues should be dry when you buff them. If the residues are still wet, you are using too much product
â€Â¢Remove the residue using clean using 100% cotton Microfiber towel, checking frequently for contaminants to ensure that you donâ€â„¢t transfer to a clean surface.
â€Â¢Apply a solution of Z-2 or Z2PROâ„¢ + ZFX -Solution as the last coat
â€Â¢Using a clean 100% cotton Microfiber towel wipe down complete vehicle with Z-6 and finally buff with a clean 100% cotton buffing towel
Maintenance (Shine) - Wash the vehicle and then wipe down with Zanio Spray Sealer (similar to the way you use Z6, but use even less). It renews/enhances gloss, reflectivity and durability/slickness.
Notes: -Do not apply more than three coats in any 24-hour period
1.Zanio can also be applied using a random orbital buffer and a finishing type (LC Grey) foam pad. Use with a speed setting #3.5 â€â€œ 4.0, lightly spray the damp foam pad with Z-6 and then Z solution and apply using a very light pressure, this will ensure an ultra-thin application.
2.If the paint film surface has no imperfections use a Z-2 / ZFX solution in place of Z-5
3.Use ZFX-solution within six hours of mixing
4.Smearing is caused by not allowing the Z-5/ZFX to thoroughly haze.
5.In colder weather you can wait as long a 36 hours between Z-5/ZFX application and buffing.
6.Unlike carnauba, Zaino can be applied in direct sunlight. The Z-6 dries very quickly so you need to work on very small areas.
7.If it does dry apply a little more Z-6 and the product can be removed.
Zanio Bros Store
JonM
