New Car "Detail", Part II
xpditor
Ahhh... the Dealer got it right this time. My car was built at 10:37 pm on the evening of April 12, 2004 on Line #1 at the Marysville, OH Acura plant. It's a healthy baby NBP/Camel Navi 5AT and weighs in a 3574 pounds 14 oz.
Father (me) is doing as well as can be expected. It arrived at the Acura dealer about 2:30 A.M. Even I am not whacked enough to be staking it out at that hour. The VIN is 42,0XX. The tires are the new "TU2" Bridgestone Turenzas. I noticed for the first time that they have a ridge that extends out about 1/4" from the sidewall near the rim of the wheel. It would seem to be there to protect the wheel a bit like the Toyos that someone showed a picture of here.
When they called about 1:00 PM, I went immediately to the dealership and scrutinized the car with all of its protective plastic and cardboard in place. Remember, they goofed on my first car and I rufused delivery as they had managed to scratch the paint when they cleaned it up.
I met with the salesperson, the head of the detailing dept., and "T", the guy who would be getting my car ready for me. We walked to my car and went over it. I told him: NO auto car wash; No brushes; No wax.
We checked the brown film that all cars have "rail dust". It is mostly microscopic ferric oxide (rust particles) kicked up by the steel wheels of the train mixed with road film. The car travels by both rail and transport truck to get to the dealer. Your new car will have more or less rail dust depending on whether it was on the bottom or top tier on the rail car. Bottom is worse. In this case, the rail dust is moderate.
The dealer uses a solvent/sufactant to get rid of the rail dust. It is very costly but does the job. I don't know the name of it. It is a commercial item. After using this, they feel the surface with their fingers to see if it is slick and smooth which is an indicator they got all the rail dust off. If finger tips drag, they will clay bar. This is not necessary on the large flat surface of the hood, roof, and trunk since most of that had the protective plastic in place from the factory.
I did a 360 degree video of the entire car including wheels. It seems to be flawless so far. I just wanted a baseline referrence for my file incase it shows up later with damage anywhere. We will know who is responsible.
Then (This is really "anal"), I handed "T" a lambs wool washing mit and told him to use it and it only on my car. I asked him to treat is as if it were his own that he had just paid $36,000 for. Then, I slipped him a $20 bill and said, "This is to show my respect for your professionalism and my thanks for your personal attention." We agreed that he would not wax the car, but just use a final detail spray to spruce it up for delivery.
I will wash and wax it myself when I get it home. There will be a sign on my garage door all weekend that says, "If this door is rockin', don't bother knockin'" I have laid in a supply of Meguire and Zaino products that should last me for years. If needed, I will clay bar again and then use the Zaino process with Z2/ZFX and finally, Z6.
Oh, yes. I understand you can drive these cars also. Fantastic! I've been thinking about it as if it were a fine piece of garage furniture.
Friday at 2:00, I pick it up. That gives me just one day to paint the garage floor and put up the new shelfs for all that Zaino.
XP (feeling much better now)
Congrats on the new TL, XP :up
I just picked mine up a couple of weeks ago, I now look forward to my 32 miles / 1 hours commute to/from work every morning and evening :bounce
I too painted my garage floor - I used the Rustoleum kit - paint chips and all. However, I'm not sure what you're using, but you might want to double check the instructions. On the kit I used, it said let the floor sit for 7 days before driving on it. Foot traffic was okay after about 24-48 hours, though.
Nothing beats that VTEC sound kickin' in.... :D
Thanks all for the congratulations. It's the biggest purchase of my life and that includes my house (25 years ago).
I am going to Home Depot to get a floor paint or process but I don't know yet which kind. I want something durable, attractive, and will not absorb oil or gas spills. I have a Jeep Wrangler that sometimes goes in there and it has an itty-bitty oil leak.
What floor paint/system to you recommend?? I'll be working/detailing other cars in there. It's a one and a half car garage about 20' deep.
http://www.rustoleum.com/product.asp?frm_product_id=56&SBL=1
I bought my kit at Lowes - but Home Depot carries them as well. My local HD was just out of stock on the color I wanted. There are other brands out there, but I chose Rustoleum solely based on name recognition. I believe it was just under $60 for 250 sq foot "kit" which it sounds like you would only need 1 kit - I used two but wasted alot on the second kit. I have a 2 car garage, and the first kit almost covered 2/3's of it.
I say kit because you get two jars - one paint, one epoxy, a citrus pellet cleaner, and the paint chips, etc.. You have to be ready to put the stuff on the floor after you mix the epoxy with paint - there's a chart(even a video!!) on how long to let the epoxy cure in the paint before you should apply it. I used a kitchen whisk on my cordless drill to mix the contents together. They are a bit tricky to mix and even out - just flatten the end loop on the whisk and it will fit in any 3/8" chuck drill - makes mixing ALOT quicker. Only mix AFTER you've cleaned and prepped the surface. Then I just used a 3/8" nap roller (9 inches wide style) with a screw in broom handle to apply - that's it. I was a little disappointed in the final appearance however. It seems to be a bit blotchy/splotchy...one of those ''otchy'' words. ;) I may have not done something properly, but it looks a heck of a lot better than the oil stained concrete I had previously.
I chose grey - looks better with my all white walls and trim - and those white cabinets (you can buy at Home Depot) and shelving units - for storing your chemicals and tools and such. I'm planning on buying a couple of them in the near future. :xyxthumbs
I can try to take some pics and upload them to my crappy free webspace if you'd like. Webspace seems to be down, but if you want to email me, I'll send them to you
[email protected]
**EDIT** I don't know about oil on the floor - but I know water beads up nicely making it easier to mop up. I would imagine this stuff is quite impervious to oil though, seems like extremely tough stuff.
Pre-lip spoiler and 35% tint - but you get the idea :p
xpditor
You may want to do a little research before painting. Especially if the jeep has been parked in the garage before and dripped some oil. The prep for painting my be more time consuming than you are anticipating and the failure to choose the right product or do the proper prep will result in flaking, lifting an peeling paint. Nothing looks worse (IMHO) than a peeling and flaking painted garage floor. I did all this research here and on some other automotive forums and found there are many people who have had some bad experiences with painting their garage floor. This didn't deter me, however it did change my mind on products. Just be informed so you know what you are getting into.
Thanks Berzerker, Brian, and all. I went to Home Depot website and they had the Rustoleum kits for $96 so I was going to get something more reasonable when I went there. Turns out they had a promotional endcap in front of the paint section and were selling them for $56. That was in the budget so I got one. Gray. The package says no special prep except for the cleaner that is included. However, I already used two different kinds of concrete cleaner yesterday and it is pretty damned clean.
I also bought one of those plastic cabinets and the stacking 5 shelves. My walls are plastered and white also. I will repaint the walls tomorrow and then do the floor. The new TL will have to spend its first night outside until the floor is good and dry.
I sat in it at the dealership today and programmed a few addresses into my navigation system. It's got 4 miles on it. The mechanic who did the pdi put 2.3 of those on.
It's still got the plastic on. They are terrified to do anything to it without my express permission.
The guy I slipped the $20 to is not working tomorrow morning. Damn! But, he said his boss, the mgr of the dept. will be starting it until he gets in. That's OK. The mgr is one of us. I can tell by looking at his personal red Chevy Extreme p/u. Rubber mats on top of carpeted mats with towels and newspapers on the floor. If he treats mine like his own, I'll be OK.
