NEW Blackfire Interior Cleaner
Sizzle Chest
Well-known member
NEW Blackfire Interior Cleaner.
I used this product on this detail https://www.autogeekonline.net/foru...2009-hyundai-elantra-restoration-project.html .
The interior was pretty beat and dirty. It had scuffs, dirt, and a bunch of unknown who the hell knows what it is all around!
I sprayed this product onto a green utility MF towel and wiped down the door panels. It removed the surface dirt, scuffs, and footwear marks with ease. I re-applied the product onto the MF towel and used some elbow grease to remove some more stubborn marks/dirt/stuck on ‘stuff’.
The product has a fresh ‘soapy’ smell to my nose and was not unpleasant…it gave the interior a somewhat fresh scent afterwards.
Two heavy areas-the cup holders and the loose change area under the ash tray are where I sprayed the cleaner directly onto the surface and allowed it to dwell for a few seconds prior to attempting to remove the grime that resided there. The loose change area had some candy or something that had melted there and was pretty sticky and disgusting. It took 2 applications and it was gone. Very nice!
Thanks again to Meghan for sending me these new products to test out and review!
Looks like it worked well on the detail you linked. Is there anything about this version that differentiates it from something like McKees total interior cleaner, i.e. a reason to reach for one over the other?
Does this need rinsing or is it like the Ultima which supposedly doesn`t (I always do *some* light degree of rinsing anyhow..)?
Why use this or the BF instead of some APC?
Not questioning the stuff, just curious. Most of my Interior Cleaners either offer some kind of supposed benefit (the "no rinsing", acidic for leathers, etc.) or are basically too weak to solve any genuine problems (so might as well just use an Interior QD instead). So if I have to really *clean* something I reach for either the Optimum Power Clean (greasy stuff) or the 3D Green APC mixed kinda strong.
^^^Accum: I did not rinse at all. Just sprayed, even let it dwell on the heavy areas and wiped with a utility MF towel.
I feel that sometimes APC can be too `strong` or harsh on interiors. IMO, a dedicated interior cleaner makes me feel better when using it. (and it could just be re-branded APC, I would still reach for it!)
