Todd@RUPES
Just a regular guy
Modern quartz-based paint coatings, as well as some paint sealants and waxes require ideal surface temperatures for maximum performance. Now you can eliminate the guesswork and ensure your products are being applied correctly with the simple squeeze of a trigger. The MicroTemp MT series Digital Infrared Temperature Gauges gives you the ability to Thermometer paint temperatures during aggressive polishing sessions to avoid over heating the paint. You will also have the ability to trouble shoot any performance variances in products due to temperature differences.
The MicroTemp MT series gauges are available in 2 variations:
The full sized MT-PRO which measures surfaces from -76 degrees F to 932 degrees F.
The pocket sized MT-100 which can even attach to your key chain and is perfect for up-close temperature monitoring.
These Digital Infrared Thermometers deliver accurate temperature readings by measuring the infrared radiation emitted from objects. The uses are endless but the results are always accurate with the MicroTemp Digital Infrared Thermometers.
