Idlewild294
Can a high quality wax by itself prevent oxidation? I've lurked around on the forum for awhile, but I just can't find an answer to my issue. I've recently aquired a Toyota Tacoma with the factory single stage white paint that came with some oxidation. I recently had all of the oxidation buffed out, and it is looking great again. The detailer used Opti-Seal and he recommended using Optimum GPS (since I prefer applying polish by hand) along with Opti-Seal to help in preventing any future oxidation. In the past, I have really enjoyed using Meguiars Ultimate Paste Wax every couple of months, but he said I also need to use a polish every few months to remove any aquired oxidation because wax alone won't stop the oxidation. Will using a high quality wax such as the Meguiars Ultimate Paste Wax once or twice a month be enough to prevent any oxidation? If so, then I assume I wouldn't need to use an AIO or a mild abrasive polish to remove any oxidation. I've researched this quite a bit, and I admit that I'm more confused then when I began my research. I know there are a lot of variable to consider. I garage my pick-up, and it only stays outside three days a week while at work. Any help is greatly appreciated. Thanks.
