Quote: Need tips on cleaning buffing pads.
~One man’s opinion~
Soak in water and then squeeze out wax/polish with your hands and rinse thoroughly twice. Hand wash with any liquid detergent (P21S Total Auto Wash) that will remove wax or polish, do not use bleach (bleach will shorten the life of your pads) air-dry or place in wash bucket and spin pad with PC at medium speed, let pad come to a stop unaided to avoid injury. When pad is dry test with a fingertip.
Clean pads soon after use, if left saturated with chemicals for a long period, foam pads will deteriorate. Extend pad life by periodic cleaning. Remove caked residues by lightly brushing the pad with a nylon brush. Never use sharp tools or metal brushes to clean pads; they destroy the foam. Store pads where they can expand unrestricted. Don’t stack pads or leave them where other objects may deform or crease them. Don't use the same pad for different products unless they are washed first (i.e. don't use for wax and then for polish unless you wash it first.
>Hope this helps<
justadumbarchitect * so i question everything*
