Need something other then Megs for PC
Todd@RUPES
Just a regular guy
I use mainly Meg's products for with my PC, and have great results. Mostly use #83/#80, and this takes care of the light stuff. My problem is that Meg's specically does not recommend using anything stronger then #83 because of diminishing abbrasives will not break down on the PC. #83 is the strongest they recommend using on a PC. I need somethign stronger (I have noticed a lot of you guys have gotten alot more out with the PC then I have been able to using #83) so what would be a product to use for the tuffer stuff when I don't wanna break out a rotary. Something without diminishing abbrasives.
Also I have the Meg's pads, the finishing, polishing, and cutting pads. I would imagine I should use this product with the cutting pads. Thanks,
you might want to try the new reformulated #2, as it can be used with a pc now (old version was for use by rotary only). i believe it's slightly more aggressive than #83. optimum hyper compound seems to do pretty well with the masses on here.
