WuNgUn
Hi all....I'm new to this forum, and I'm learning lots. However...
I want to know how to do a complete exterior detail.
My ride is a '02 SVT Focus (Sonic Blue)
I will be getting a PC orbital polisher in the spring, as well as a clay-block setup...
As of now, I've been using a Teflon Gel car wash and Mothers 3-step prewax cleaner and glaze and carnuba wax (however, I switched to Gold Class as the 3rd step as it last longer and shines better IMO), all hand applied with MF clothes...I take fairly good care of my cars finish, so it isn't in too severe of a condition, but I want it to look perfect!
I always use only back and forth rubbing action whenever I'm in contact with the paint, so 'spider-webbing' isn't a major issue, but somewhat noticable...
What I want to know, what wash solution do you recommend? Should I do a prewax clean prior to the claying?
Should I use another cleaner after the clay, prior to polishing (glazing)? Maybe just another wash?
And is a glaze not a real polish, like I've read, but just a scratch filler? If so, I need a fine polish (and maybe a slightly coarser grade polish for some small scratches)...what do you recommend?
Is Meguiars Gold Class good stuff, or is there something else that gives a better shine?
Should I just use the PC for the polishing step, or can (should) I use it for the final 'waxing' process as well?
Thanks!
Thanks!
