Need help with Menzerna & Holograms
Working on a 98 grand am. Repainted about 3 years ago using black PPG paint.
I am using: PC, Excel detail pads, QD, water/soap for washing & a wash mitt.
I had bad swirls before from my wife washing it with a sponge, I buffed it about 8 months ago and it came out flawless. I must have opened up a can of worms.
I started by wash/clay/dry with WW
Then hit the paint with Menzerna IP with the PC and a yellow pad.
I pulled it out into the sun and holograms like a Mother. I used it on speed 4 & 5 and kept the surface wet with QD.
Buffed with a MF.
So I tried to get something with fillers---3m swirl mark remover for dark cars green pad--No luck there either. I then tried Menzerna FP II with a green pad, no luck, still there. Tried Meguiars swirl mark remover 2.0, no luck.
What the H am I doing wrong??? I've done this process on 8 cars using IP, FP-II, Glaze & FMJ and have never had this happen.
:work: :wall :wall :wall
why are you lubing the panel with QD while you polish? that will affect the polish's ability to do its job. and with IP, i would suggest running the PC @ 5 at the minimum, preferably @ 5.5 - 6. then follow up with FP II with a polishing pad. let the polish do its work and don't add to it with QD.
Mighty HD said:
...and kept the surface wet with QD.....
That, my friend, is your problem. The addition of QD to the surface is making the surface more slick(less friction). Less friction = less heat = abrasives don't break down properly. Take your time and work it again.
On this site:
http://www.properautocare.com/meninpol.html
It says to mist it with h20, on 3.5-4 which I did, then I tried QD, then Alochol/h20 50/50. When it was nearly dry, I removed as much as I could with a MF, then spritzed it a bit with the 50/50 mix and it came off.
So you guys say to use IP by itself with NO lubrication at all, work it until it's dry on 5 or even 6?!
I got frusterated with it and got it cleaned off and did a crap wax job of #27 over it for now. It seems that a lot of the holograms went away but they're still there.
Now next weekend when I do this again:
IP with NO lubrication on 3 starting, then crank it up to 5. (How do I keep it from drying out so fast?)
Then FP II with or without lubrication?
Glaze with a blue pad
and fmj by hand.
I'm a bit flustered because I've done this same process on the black car once before and didnt have this trouble---maybe I opened up a can of worms.... :frusterated:
Thank you dearly for the replies.
Mighty HD said:
On this site:
and fmj by hand.
yeap, i start at 4.5/5 and end at 6. works great, very little hazing, even with a cutting pad. I never use a QD when polishing.
I've primed the pad with water always but only one quick mist as I don't want to dry buff and get the buffer pad chattering
Had no problems but I know one person who can use Menz by rotary without water and he's better than me with one
So should I use all Menz products with rotary without any H20 on the pad?
My pads are damp on the rotary from washing them out/spin drying and I don't have this problem.
On the PC, I mist 1 squirt of S&W or water on a dry pad, when I prime the pad and don't have this issue either.
If you are spraying QD on the panel you're going to create a mess with sling, and I agree that your polish will be more aggressive.
i just got some menzerna FPII and a little brochure came along with it. The brochure has directions from what looks to be Menzerna, and shows the user misting the pad w/ water.
I have had really good results misting a microfiber pad on the PC , @ around 1-1.5, with moderate pressure.
It could be that the car is dark, and that you are noticing micro-marring and hologramming more b/c of the color.
....You could also try in a spot... FPII on a misted microfiber applicator / rag and do a small spot by hand. If that works to resolve the problem, slap some micofiber in between the pad and the pc and repeat w/ the machine....
COULD YOU LET ME KNOW IF THIS WORKS 4 U?
I'm going to attempt to do this again this weekend hopefully.
I did the neighbor's car 2 nights ago, using IP, FP, and FMJ---using the same methods I used on my black car, and got NO holograms. he has a factory black paintjob however on an envoy. I wander if it's because I have aftermarket paint thats giving me the trouble? I think that there is nothing better than factory paint----the aftermarket seems to be too "soft" and easily scratched.
