Need Help, PICS!!
Beason
EDIT: Wrong forum, please move to Detailing or Autopia Univ. Thanks
Here are some pics of a black tahoe i will be working this weekend. I have the following products to remove these and would like some imput.
DACP
Meg. Swirl Remover
3m Fine Cut Compound
Meg Red and White Pads
CMA White and Yellow Pads
keep in mind that this is my first time to do anything to this car, I just picked it up a week ago and this is the first time I will have time to detail it. Its a 01 Black Tahoe with just under 35.000 miles. Thanks in advance.
Hmmm well I would go with the DACP and yellow pad on that one.
Now some people would say to use the white first and something less aggressive but from the looks of it, you won't be able to get ALL the swrils out unless you use DACP or maybe even something a little more abrasive. (not that you should, just saying)
Try that first and go from there.
I'd start with a white pad on the PC with the SMR. Go slow and methodical.
Good pictures. Use that same lighting to remove.
I did an '03 Black escalade yesterday which still had 'perfect' paint, at 5K. Well, bugs were an issue, but...
Suggest your owner find a different car wash...
Jim
Jim
I am the new owner :) I picked it up used in houston. believe me no one else will ever touch this car beside me aslong as i own it.
I'd use the DACP or the Fine Cut and the most aggressive pad I had. Do this to level the paint and remove the more serious scratches and swirls. Follow up with #9 and a yellow pad and the paint should be damn near perfect.
