imported_RedlineIRL
The other day I managed to get a rock chip on the front bumper of my car, and it has been driving nuts big time ever since
So I need some help and advice on touching it up. Normally, I don't worry about the tiny ones that are hard to notice but this one is fairy decent sized IMO and annoying to look at. It chipped off an area about 1/8" by 3/32" in diameter, and the fact the the way that it bounced off it made a white mark in some of the area that makes it stand out more from a distance.
The thing is though, the front bumper was repainted a couple years ago so I am not really sure what options will work best and match the best. As of now I am thinking of just going shop that spryed it and have them mix up a small amount of touchup with base and gloss, and use that over the typical touchup bottles that never look right. I thought of using the Langka kit to smooth it out, but their site mentions that it is best used for factory finishes. Is there anything out there I can use that will smooth everything out once I fill the area in, either sold or something I can do myself?
To be honest, I am a little worried about touching up an area of this size, thinking that it might look worse afterwards than before I touched it at all. Is it possible to get this size of a chip to look better? I know it will be really hard to get looking perfect as if it was untouched unless I wtsand and put many many hours into it, which involves much more skills than I have at this. As long as it unnoticeable for the most part from a couple feet distance I guess I could live with it. Another thing that has me really worried since the front bumper was repainted, is it possible for the touchup to get under the existing pnainted areas surround the chip and start to lift the panit up? I was planning on doing thin multipe layers to build it back up with a toothpick or small brush, or will it be better to fill it with a larger blob and try to smooth it out?
Do you guys have any reccomendations and links to where I can buy some real good quality fine tipped touch up brushes, I can't seem to find anything good at all locally?
Sorry for all of the questions at once, but I really want to get all of the information I can from you all before jumping into this. Plus I want to be fully confident that I can do a good quality job on this. Thanks for any help at all with this
