Nanolex WashCoat is almost there...
Florian@Nanolex
Hey guys, we shipped a larger quantity of Nanolex WashCoat to the US and it should be there in a few days :)
Nanolex WashCoat is a truly unique product – the application is very quick and very easy, it literally takes a few minutes only. The product is applied during the wash, right after the final rinse.
The car needs to be wet, the product is applied to it than by either foam gun or pump sprayer. It needs to be left on the paint for 1-2 minutes, after the rinse it will work straight away – it has to be rinsed off to work properly.
You can find more videos right here: WashCoat | nanolex
WashCoat can be used as a stand-alone product as well as a maintenance product. Used as a stand-alone we recommend 50ml of product, for top-ups (it works well on any other sealant/wax, like the shampoo) we recommend 20ml.
The concentrate needs to be diluted right before it is used, the mixture will become unstable and fall out after a couple of hours.
It’s the first product that makes a noise when it is on the surface, make sure to listen when you test it ;)
The durability is at least 6-8 weeks or 4 washes respectively. If Nanolex Reactivating Shampoo is used the durability will of course be prolonged.
Gloss is visible enhanced, the surface becomes smoother and also easier to clean!
The product is perfect for the winter months since the application is so easy and there is zero curing time – also ambient conditions do not matter.
Any questions and comments are much appreciated!
Cheers, Florian
Finally had the chance to break down some WashCoat bottles into sample size and now ready to send them out to whomever is interested in testing.
Its crazy good, so easy to use, just wash your car, coat with WashCoat, let dwell rinse and you're done.
I would love to see a video using a pump sprayer. I think you would use less product that way.
The spray on and rinse off is similar to Permanon and CarPro Hydro2 both of which I have. I am interested to see how Wash Coat stacks up.
Got my sample today. How much should I put in a 1 liter pump sprayer? Might be on the instructions just haven't had a chance to read yet. :)
