Pinnacle Black Label coating is one of the easiest coating products to apply. If you are a beginner I would suggest this. No garage required. Cool paint is recommended.
Just an FYI, I applied this coating last night. It`s basically as easy as applying a sealant like Powerlock or BFWD.
I started just in small sections, but once I started rolling - I applied it to a whole half the car and it wiped off easily no problems. Applied it heavy , applied it twice - no issues.
I don`t know how long it will last or if it`s really a coating. But it`s not just a sealant, because it reeks of IPA.
But as for ease of use, I can`t imagine anyone screwing this up.
The caveat is, you have to use the Pinnacle Prep Polish (or so they say). This could be a drawback if your doing a correction - because it`s a whole separate polishing step - opposed to just doing an IPA or Eraser wipe down, at least per the instructions.
I found Gloss Coat to be far easier to apply. Takes a couple. Inutes longer to haze, which allows you to work in bigger sections and it was an easier wipe off.
