My take on sealants and waxes i have used
imported_Grouse
All the items mentioned were fully used at least a 16 oz bottle over as many cars as that would cover. Most ranging from 3/4 -1.5 oz per application depending on the product and how it was used.
Lets see i may have more exposure than most.
On and off 1-5 1 being a pain 5 being super easy or no wiping off
Durability 1-5 is 1 month to 5 months of daily driver use in seattles winter.
Correction rated 1-3. 1 can remove wipe marring, 2 can remove light buffer trails, 3 would be a final polish correction ability.
Klasse twins. Used together , The on is easy the off is a biatch 1 out of 5 comparatively. durability is a 3 out of 5 correction 1
FMJ On and off is 4 out of 5 durability is a 2.5 out 5 correction 0
PB ex-p On and off is a 3.5 out of 5, Durability is a 2.5 out of 5 correction 0
Pb ex on and off is 3.5 out of 5 durability is a 2.5 out of 5 correction is 0
CG jet seal on and off is 3.5, durability is 2.5 out of 5 correction 0
Opti-seal on and off is a 5 out of 5, durability is a 2.5-3 (still testing) correction 0
JW prime/jett combo. On and off is a 2 out of 5 durability is a 4 out of 5 correction 1
CG 50/50 on is a 3.5 out of 5 and durability is 2.5-3 out of 5 correction 0
Natty's blue red white on and off is a 2.5 out of 5 and durability is a 2.5-3 out of 5 correction 0
Apo 60 on and off is a 2.5 (rotary lots of sling with correction capabilities) durability is 2 Correction capabilities is a 2 out of 3
Einszet Metalic polish and wax on and off is a 3.5 out of 5 (machine, rotary, pc, flex) Durability is a 2 correction is a 1.5
Einszett glanz wax On and off is a 3.5 (have to work in smaller sections not whole car) Durability is about a 4, correction is 0
Swiss wax Cleaner fluid on and of is a 2, durability is a 1 (meant to be used with wax) correction is a 1.5
Swiss wax onyx On and off is a 3, durability is a 1.5 correction 0
Swiss wax concourso on and off 3, durability 1.5 correction 0
I don't about you but here in Ohio I have gotten 4 month of durability out of JS on my work vehicle with easy on & off and no type of "booster" wipe downs between washes.
I would rank it a 5 on 5 off (1 being hard and 5 being easy) w/ 0 correction
Others have said similar. it seems to be a hit and miss. I know as many people who have the same opinion as me as i do people who share yours.
this is how i rated them. your exp and rating may be considerably different. The sample i received of js is by now many months old. I received it last april i think. That may be part of why i don't really care for it.
Totally agree with your findings about 1Z Glanz. Out of the others I have used in your list, none were worth even mentioning. 1Z is a great sealant. The pre-reformulated was even better.
Looks are about prep work. and very very subjective. as far as glanz it gives me similar looks to 2x fmj 1x cg559 and JW prime/JW AJ cg5050 combo's Glanz gives me that look in 1 layer.
In what way?
I tried the old formula a couple of months ago and LOVED the look on solid black. It ddn't have the typical sealant look - even the newer ones. It had a real warm carnauba look about it without the shimmer that carnaubas give. It really darkened the paint and had great depth but less gloss than, say NXT or Megs other waxes.
Thanks.
I'm actually surprised about Swissvax Concourso rating considering its price...
What do you think of P21S 100% Carnuba Wax? Thanks...
