My New Toy.....
Addicted2Bling
I took some photos with it last night and it is an amazing camera, so simple and so many different options, very user friendly and it's built like a tank. Silky smooth graphics, HDMI hook-up on the side. Oh god I love it!
:party:
wow..man you'll have some fun with that full frame gear... now you wanna start saving pennies for some fast glass.
I would suggest buying Lens Align which allows you to micro adjust the focus of each lens. I have the 50mm f1.4 and frankly it's not usable any wider then f2.5 My other lens are all good wide open, but then again they are all L glass but everything needed to be micro adjusted. Congrats, I have the 5Dm2 and love it - you won't be disappointed.
Doesn't the camera have a built in micro-adjust? I know the Nikon D7000/D800 and my D600 have the ability to tweak focus based upon the lens.
Yes, many of the newer DSLR have the micro adjust feature; however, you need an alignment/calibration device to be able to "micro adjust" the lens against a standard reference. Shooting brick walls won't get it done. It's shocking how much the focus is off. Consider this - all lens and camera bodies are built to a tolerance. Let's say that tolerance is +/- 10 points. If the body you happened to buy is -9 and the 50mm lens is +8, the individual components are within spec but overall you're way out of the acceptable tolerance range. The camera manufacturers realize this which is why micro adjust found it's way into the feature set. I would suggest the regular version and not the plus but I don't know any other way to actually use that feature. I was one of the early adopters of this device & believe it makes a significant difference in the performance of any lens.
LensAlign
There are some free test cards using a similar technique: angled ruler to help determine the correction factor.
Personally I've tried some of these "free" instruments but without success. Obviously YMMV but being a professional, it was worth the money to buy the lensalign kit. BTW, think xrite and a few others have come out with similar systems at a lower price - probably worth investigating if your interested.
Wow I had no idea about this. Thanks for the tip.
I found this off of some camera forum on google,
Some Camera Forum On Google said:
My quickie technique is to use a target parallel to the sensor as suggested, 50X the focal length away from the camera, which is mounted on a tripod, aperture wide open, target in good light, and then let auto focus do its thing and focus. Then switch to Live view in the most magnified view. If that is in focus already, then you are done. If not, then focus manually via the magnified Live View, and then switch off Live View. Looking at the distance scale, press the AF/shutter release to initiate AF. Note which way the lens turns and how much.
Having done this, adjust the microadjustment proportionally and in the appropriate direction (which you will learn to do with several attempts.) Then, hit the AF/shutter release again to make the camera AF again (optimally from an out of focus point). Switch again to Live View in the magnified view. If it is in focus already, then you're done. If not repeat the cycle by focusing with Live View again, then switching off the Live View, then use AF while observing the lens to see how close you are (if the lens barely budges, you are very close), and then microadjust proportionally.
You will get closer and closer. And if you go too far, the lens will move the opposite direction when you press AF/shutter release after having focused in Live View.
This is faster than using files (actually taking shots), and IMHO, the Live View magnified is just as good as the monitor view in the end, or close enough.
The tripod, and a cable release help to avoid spurious results.
If your AF and Live View are in agreement, you have succeeded. At this point, the files or monitor view of the images will substantiate the result in my experience.
I'll probably give this a shot first
