My list, buffing suggestions?
98bmw323is
So ive done some looking around for pads/polishing compounds.
I will be using a rotary buffer (I have used this before so im not worried about its strength)
as for compounds and polishes:
Heavycut: Meguiars #4 heavycut cleaner
Medium cut: Meguiars #83 dual action cleaner/polish
Lightcut: Meguiars #2 fine cut cleaner
Polish: im looking for something without any fillers, suggestions?
Light polish: im looking for something without any fillers, suggestions?
Finish: Meguiars #81 hand polish
as for pads im kinda lost as to which ones i need for the above products.
I was looking at these http://www.autogeek.net/curvededge.html should I just get 1 of each?
*comments suggestions* thank you.
Since you’re going Meguiar’s on the medium to heavy cut why not try #80 or #9 for lighter cut?
Personally, I prefer flat pads over the curved.
PC.
Unless you have a specific fondness for the #4, I'd use something from the 80's series instead (e.g, #84, #85).
IIRC the newly reformulated #2 still has a bit more cut than #83.
I'd consider following either #2 or #83 with #80 (time-proven combo). But yeah, it leaves some stuff behind. You could search out my fave, the discontinued 3M PI-III MG (05937), it's still out there.
For a filler-free final polish I too would try the FPII if you really need it, which you probably won't if you use the 05937 or the #80.
I dunno if there's much point (IMO) with using a Meg's pure polish (#3/#5/#7/#81) after saying you don't want any fillers. I seldom get any real benefit from using pure polishes on b/c paint that's been well prepped anyhow.
If you're using this on the '98 Bimmer I dunno about those aggressive products. My '97 E36 needs some real correction and I doubt I'll use anything nearly that potent on it.
I do OK with the Meg's pads, at least for the rotary. Most of the time a 8006/polishing and 9006/finishing do the job.
