My Experience with Quick Detailers....
I remember when Meg.'s came out with the first QD... thought I'd never have to wash my car again:huh::Dancing Dot:
I use it for this and that but a lot less than I used to. Mainly a clay lube. I also give my customers a small bottle of QD along with a good microfiber for bird incidents.
I like Adam's QD, seems to do a good job, priced right for a gallon and it has a pleasant scent. I'm going to try making a gallon of ONR up and using that for a QD. Anyone tried it for that?
Haha.... I thought the same thing! Just spray and wipe right on the DIRT! What could be easier?!!!:Dancing Dot:
Great idea! I may adopt that...(with your permission!):clap:
ONR as a QD is excellent. I mix about one ounce with water in a 32oz spray bottle. (I don't know if that's the recommended ratio, but it seems to work well.)
This is a very nice QD. Good for glass cleaning too! Smells good (like fresh laundry) and leaves a slick finish. Cheap too! Hard to find fault with ONR/QD!:biggrin::clap:
Excellent,:clap: thank you Bill, I'll give it a try!
I mixed up a quart of ONR at the higher lube strength for claying and had quite a bit left. I tried it as a 'spray n wash' product on a bike that was dirtier than you'd use a QD on with great results. No marring even on Harley's miserably soft Vivid Black! A very versatile product!
TL
I mixed up a quart of ONR at the higher lube strength for claying and had quite a bit left. I tried it as a 'spray n wash' product on a bike that was dirtier than you'd use a QD on with great results. No marring even on Harley's miserably soft Vivid Black! A very versatile product! TL
:clap:I agree! I always keep plenty around. When my gallon gets half down, I order a new one!:Dancing Dot::biggrin:
ONR Dilutions
? Car wash solution - 1oz / 2 gallons
? Detailer?s clay lubrication - 2oz / gallon
? Quick detailer (QD) - 8oz / gallon
? Wet-sanding lubrication ? 6oz / gallon
