MuttGrunt's Half detail: 2004 Honda S2000
MarcHarris
This took place a couple weeks back while I had a nice long weekend planned to polish out my baby during the ugly cold weather. Turns out that long weekend turned out to be hectic, so I just did the entire front end, and will do the second half come Spring / another opportunity.
with limited time to use the garage, a hectic weekend schedule (helping my sister and her husband move, girlfriend taking me to a Piston's game, studying for the 5 classes I'm taking, etc), and cold temperatures (my current weather), I wanted to get done as much as possible with what I had to work with. additionally, because I plan on keeping this car until its death, I opted out of trying to achieve 100% correction and opted for a good 95%. I didn't need to take the clear down as far, and it leaves me a lot more room for future buffing.
Products:
1000W halogen lights
extension cord for lights
Makitia 9227C
3m backing plate
heavy duty extension cord for buffer
Menzerna IP
Menzerna 106
Two bucket wash system with grit guards
ONR (1 cap-full per gallon)
lambswool mitt
chem sprayer with citrus degreaser diluted down to 1 part to 20 parts water
chem sprayer with water
blue painters tape
CG Luber
Adam's clay
CG Jetseal109
99% ISA
Eurow Shag microfiber towels
Detailers Domain Uber towels
Viking microfiber detailing towels
LC white flat pads
LC black finishing pads
wax applicators
LSP: Dodo-juice Supernatural v2.02
Too cold for hose, so I had to go the route of ONR. This is a great product that has gotten a lot of attention mainly due to it's ability to allow for washing without inducing defects in the winter, as well as being environmentally friendly (wash your car with only 5-6 gallons of water vs the usual 40+). Don't get me wrong though: I look forward to using my foam-gun come sumer time :D
Everything is set and ready to go!
all clayed and ready for inspection. Eurow towels were used for the ONR. I really like these for removing water/dust/quick detailer. they're very dense and thick, and the long microfiber stands absorb a lot of water. On the downside, they lint...and lint...and lint. A good prewash helps to solve that issue, but won't eliminate it. The green mf's are the Viking detailing towels i picked up on clearance for 87cents each (Thanks BigAl !); they're huge, soft, and can't be beat for the price. As things got going however, I had to switch to my "uber" towels to remove polish and wax. I thought some of the marks on my paint were do to the towels marring (the green ones), and once i switched to the ubers i no longer had this problem. Because half of my ubers are the smaller ones, I found they were much easier to work with, and their slightly longer pile made wax/polish/sealant removal a bit easier.
My paint is in much better than average condition due to the way i baby my car, but it has never been polished and under the lights it shows:
swirls and scratches from back in military when I had no place to give it a proper wash and therefor had to go to "swirl-o-matic" car washes. Very sad, but very true :cry:
time to test and see if my combo of polishes+pads will work. I didn't want to get too aggressive with the correcting as Honda's are known for their soft paint. As I've learned, always start with the least aggressive method and work your way up if you're not happy with the results.
left side done, right side untouched (this is after an IPA wipedown to insure the polishes used were not just "filling" the defects and they were in fact truly removed)
this time the top is untouched, and the bottom (hood) is complete:
with the hood done and it getting late (and cold), I called it a night. first i made sure the completed hood got it's IPA wipedown, then applied the Jetseal109 to sit overnight
The next day I began on working on the fenders and front bumper. As you can see in the picture, there are still many defects from 57k+ miles of driving to the paint. little divets, dimples, paint chips, etc were all present. With these areas getting polished however, they contained no more sharp edges so they don't stick out as bad in light.
Half the bumper done, half not:
now check out the clarity to that same front passenger fender:
side by side, the completed fender vs the passenger door under halogens:
driver fender step by step.
before:
after polishing with Menzerna IP (notice buffer trails/marring which need to be taken away, but a much improved finish)
and after further finishing down with Menzerna 106 (now CLEAR)
after IPA wipedown:
and last but not least (for now...)
driver fender vs driver door :eek3:
once again, take into account my paint was actually in pretty good shape (for it's age/milage). Red can get hazy and lose it's depth (therefor making it look lighter/pale), but some darker colors like blues, and of course black show defects much worse. the paint turns pale, hazy, and loses its clarity with all the defects in the clear coat.
I found this paint was somewhat a pain to deal with due to the soft pigmented clear used on the New Formula Red paint. Cleaning my pads VERY often helped, but was still annoying when coupled with cold temps.
So after taking off the Jetseal (which is the easiest to remove sealant i've ever used) from the rest of the front end and letting it sit awhile, my S was ready for some real carnauba wax, and in this case i wanted to give her the best i have...
here she is all waxed-up late Sunday night post-Piston's game (they lost to the Rockets :( )
I let the Supernatural sit for about 50 mins before I came back to wipe it off. The solvents used in this wax seem to work very slowly evne when I used it back in the Fall in warmer (50-60degree) weather, and I'm not quite sure how the cold weather (around 20-30 degrees in the garage) might affect it. Regardless, after removal, I was delighted to what I saw. Surely she'll be getting more coats once it's warmer out.
finished and outside:
even in low light with a point and shoot digital, the reflections appear more crisp, clean, and wet:
the second half will be done most likely once it's a tad bit warmer.
yeah, yeah - I know the wheel wells/ wheels aren't looking too pretty, but she's going right back into storage so I didn't take all too many pics. Once it's warm, I'll give you guys some better pics. Until then, please excuse the point-and-shoots as well as lack of day shots.
Doing, and posting this detail also allowed me to look into my wax a little more to get some answers about what version I truly have, and i know they've switched from their first version (v1) to a newer slightly different slightly "better "form (v2). my 30ml sampler is the v2 i know, and it's very grainy due to the really high carnauba content. if you look at the wax, it almost looks like a mini-tapioca puding or something. Well for my full size wooden tub, it's not like this, which of course has had me wondering what this stuff is. after doing a little searching, I came across some responces from Dodo Juice posted on Detailing World. they had this to say:
*ALL* the Supernatural made by us since July/August last year has been v2 (panel pots, wood, plastic), so fret not. *ALL* plastic 200ml pots are v2 of some variety. Ads, you have the latest v2.02. It is unlikely any v1 has been sold in 2009 at all, unless a couple of old units have been left over since June 2008 on a shelf somewhere. You can ask the shop selling the Supernatural what version it is, and they can ask me if unsure themselves, it is easy to tell... v1 is hard texture, v2 is soft. v2.00 and v2.01 are grainy. v2.02 is smooth and buttery.
As for a v3? We will certainly improve SN again to keep it in the best performing wax league and to fend off competition. However, whether or not we announce it is up for discussion. We have improved all our wax formulas, but the Supernatural announcement caused problems for traders with old stock and confused customers. We may just make it even better and keep schtumm
so it appears i have the v2.02, but will be ale to tell better once i use more of it. I used such a small amount (as its made to be put on in super thin layers) that i can't tell quite yet how smooth the stuff is, while my sampler is half gone and easy to spot.
I hope this info clears up some questions to anyone who has any amount of supernatural, or is interested in getting some.
the info I found on Supernatural version can be found here: http://www.detailingworld.co.uk/forum/show...t=102430&page=4
thanx for the comments/questions/etc, and may the rest of your winter be salt free, above freezing, and short! :thumbup:
