Finaltheorem47 said:Buddy, the 4.0's are pushrod engines, there is no 4v version!
The 4.6 is a modular over head cam engine. It comes 2v as a GT or 4v as seen in cobras and mach 1's If your planning on swapping a 2v for a 4v, you really need a 4v engine to pull the parts off of, even up to the wiring on the engine, you need to swap it with 4v stuff!
mysteryan said:If the block is similiar enough, swapping from SOHC to DOHC would require a head change. This is done with many Hondas as well. It's not cheap considering you're pretty much replacing half the engine. SOHCs work great turbo, your power yield is a lot more significant going this route than most NA routes.
David Fermani said:The only 2 things you'll need to do to blow away a V8 = Big turbo & gut it.
brianshaeffer said:The 4.0 engine in the 2005+ Mustangs is not a pushrod engine. It is a SOHC, 2 valve engine, based on the old German pushrod V6. The SOHC version has been in production since 1997 in various Rangers and Explorers.
