moving the buffer too slowly creates swirls ?
chip douglas
Would you agree, or confirm that given one use a polishing pad + polish, spinning the buffer at 1400-1500 rpm, can create or introduce marring/swirls in the finish, if the rotary is moved too slowly over the paint surface, because it then has time to mark the paint surface more ?
Thanks
No, I wouldn't say that. Marring and swirling is caused more by poor technique than rotary speed and polishes. I actually use a polishing pad and light polish at 1500 rpm to finish after cutting to produce a great finish.
Chip, it's easier to give you some do's rather than don'ts when using the rotary. Keep your pad clean and primed. If you let it run dry, or overload the pad with caked polish, you will feel the rotary start hopping. Work small sections 2'x2' at a time. Keep the pad as flat as possible when polishing, on my final pass I will slow down to about 1000-1200 rpm and lay the pad flat to the surface to prevent holograms. Let the pad flow freely across the surface. This is more of a "feel" thing that you will acquire with experience, but you'll know it when you got it. This is especially difficult on vertical surfaces. Try to follow the natural direction of the polisher and learn how to make passes without having to fight the polisher. The rotary is a much more accomplished skill than a PC, it takes time and experience to master it. The only way to really learn it is to use it. Most people learn by working on a junk car, and this is a good idea. I learned by working on a friends beater car. You can also go to the junk yard and pick up a body panel to work on too. Hope this helps.
Always keep the buffer moving. Not too fast, because then you get careless. Always reduce speed when buffing near edges or when the contour of the paint changes. Rotary buffing requires some common sense, but gets a bad rap for no reason, in my opinion.
