mothers sealer and glaze and nxt question?
Kool_ZX3
How much pressure should be used when i use it, should i rub hard of just put a light coat like you would wax??
also with nxt i used it today let it dry but when i went to remove it didn't come off easy, that mean it still has to dry more? It didn't come of smooth and i let it sit for like 25 mins
also after i removed it all and buffed it the finish was still kinda riugh and not smooth like when i did my TWPUG last year. anything i am doing wrong here, what should i be doing?
I know with nxt if you get spots that didnt go on thin its a pain to remove. Just remember to keep it thin
with selaer & glaze, just apply thinly to whole car & then remove with a mf cloth - u should have no trouble removing it, thick or thin. its a very under rated product too...
nxt really needs to be applied very thin & then it removes easily. but if you do put it on thick in some spots gently move your mf cloth over the area with a few passes & that should remove it.
both r gr8 products & i have used them together with fantastic results too!
:wavey
