animes2k said:What about some of those gel-packed mechanics gloves?
stevet said:With the right counter weight, pad, and backing plate combo plus holding the PC by the head instead of the handle I get very little vibration on 6. Also make sure the pad is perfectly centered. Even if it's a little off it will make a bid difference at 6000 opm.
:upstevet said:With the right counter weight, pad, and backing plate combo plus holding the PC by the head instead of the handle I get very little vibration on 6. Also make sure the pad is perfectly centered. Even if it's a little off it will make a big difference at 6000 opm.
Scottwax said:Same here. Removing the handle and holding the PC by the head works great. In fact, to me, it seems the vibration is actually less at higher speeds.
