Mobile Water Tank/Pump Set-Up
I got a van set up If you have a northern tool close to you I will get your tank there for the price of that one I got 150 gallon at northern. Not saying you need a tank that size but you can spend less money for that size tank. I also bought one of those pumps as a just incase thing and never used it. I say learn from me over spending get your system set up with PW and tank and see if you then need the pump because the PW is starving for water. hope I helped
My tank was $189 at Detailers Supply. I also use a pump like that. I bought mine at Harbor Freight for about $25. It runs off 12 volts. I use the DC side plug to keep a continuos flow so I do not burn up my pressure washer.
