mobile crusher
senmir
At the same time as the convenience of mobile crushing plant in operation both in terms of the YGE another series of mobile crushing and YSF series of mobile crushing plant for the common advantage. YSY series of stone crushing station is under the cone crusher and crusher and crushing the different effects of crushing principle developed out of the feed material size requirements and there are very different. Strong overall coordination, integration, unit installations. Reasonably compact layout for the site construction saves time and space, increased flexibility, while eliminating the need for a large number of site infrastructure, significantly reducing investment costs. Body width is less than operating trailer, car chassis unit higher. Turning radius, easily broken field area in the rugged running of poor road conditions more conducive to the construction area. Can direct output fine-grained aggregates finished, configure the cone crusher which will adequately play a crushing function. Full-featured, directly reduce the cost of transporting materials. Units can also lengthen the materials directly into the transfer carriage broken bucket, to facilitate the timely transportation. The second isolation, mobile Crusher hydrostatic principle. Equipment, small vibration, but also conducive to the implementation of installation. And work stability, cone crusher broken efficient material layer. To a large extent to save time. To single group of independent production, device configuration flexibility. Can also form joint operation with the rough broken equipment. Unit in addition to equipment purchase of diesel generators to power the unit, but also targeted to the workflow system can configure the power supply unit combined, significantly improve the adaptability of the equipment.
