MMMM....new stuff arrived today..
COLDZ71
Just got my order in yesterday. I ordered through AG, and recieved everthing in three days. Got free shipping on top of 10% off. Talk about a sweet deal.:woot2:
So do you think these Cyclo pads will work well with my PC? I searched alot and decided to go with these 4 inch pads instead of trying to work with the 6 inch pads I have been using. I will use these with OHC, OC, and OP. I think a rotary will be in my distant future but I am hoping these pads amp up the correction factor using the PC. Just thought I would share.:)
Wow, do you really use that many white and greens in 4 inch? I have 2 orange and 2 yellow in that size for correction. If you are using white it's usually with a fine polish and I have never really fit green in my corrections.
That being said, the 4" pads are much better for correcting. However, remember that the PC/UDM has its limitations. Also, when using those be a little more carefull than bigger pads, IT IS possible to burn paint with a PC/UDM and 4 inch pads.
Good Luck!
the cyclo pads will work fine with the PC as long as you have the correct backing plate, in which the picture shows you do...
Good Luck!
I don't know, I have never used 4 inch pads with my PC before. They were the cheapest when you bought them in packs of six through AG.
Yeah someone said you can burn through paint using the 4 inch pads. I will have to pay a little more attention the first time I use them. I am hoping these will help take most of the defects out of my rides. Thanks for the tip!!
Cool..... The backing plate I ordered was a 3.5 inch LC. It goes right out to the edge of the velcro of the pads. TOTL sells a 4 inch plate which I thought would be better at holding the pads, but after I see how this one lines up, I think the 4 inch one would only get in the way more.
man, AG has so many products that I forgot about Cyclo pads. Had I known I might have picked up some of that 4" wool. My order for 4 inch pads should be arriving this afternoon, but I got the LC CCS 4" pads.
They look like they will work fine and considering the color of the pad seems to coincide with the function and color of LC's, I wouldn't be surprised if those are relabeled LC pads. I'm sure someone else could chime in.
