Mirror finish!
rwh
OK I've been away from the forum for a while now so bear with me. I have a car that for all practical purposes, the finish is like new. I would like to remove some very light (VERY) light spider lines. I have used the P21s GEPC with the P21s wax. I do have a porter cable polisher also. Which products would you guys recommend and the proper procedure to apply? Looking for as close to mark free as possible. The car is not a daily driver so I am not overly concered about how long the wax will last. The car is kept in a garage and covered 80% of the time.
Megs SFP will work on minor swirls. So will 3M SMR which can usally be bought at Pep Boys, etc. Use with a white pad and then follow with GEPC. Good luck.
Depending on just how light the swirls are, you may be able to get away with using 1Z metallic polish or paint polish if they are a little tougher. What color/make car is it by that way
freedre -- was that using SSR1 by hand or PC? i've heard good stuff about the SSR line, but don't know how to use it to tackle the problems.
alex
