Microfiber
B@tm@n said:
Do you clean the microfiber towells or do you just use them once?
If you clean them, how do you do it?
If you are buying them from danase.com just use them once and throw them out and buy new ones.
KIDDING! You wash them. I prefer a microfiber wash in the washing machine but some people use regular liquid detergent. Some tips for washing them:
1. DO NOT use powder detergents.
2. DO NOT use bleach
3. DO NOT use fabric softener or sheets
4. Wash microfibers together and not with other clothes or items.
I also use Woolite and the warm/warm setting. I then run an extra rinse with about 1 cup of white vinegar.
If they are really nasty, I'll put in a scoop of the DP citrus pad cleaner - seems to help a little.
Like Bob said, make sure you don't wash any terry towels with them. When I first started this whole obsession, I washed my first load of MF with terry towels. I had to toss all the MF because the lint and fuzzys that were stuck in the MF.
I also use cheap MF for the wheels/tires. If one of these falls on the ground, it goes into the garbage. I don't even try to clean these. With my nicer MF, I will try to clean them, but if I can't get it all out - in the trash they go.
New MF towels are cheaper than a paint job and/or my time to remove all the swirls and scratches!
Brian
I actually use bi-o-kleen's traffic lane clean as a pre wash. 1oz to a load. Then Chemical guys microfiber wash. 2oz to a load as the main detergent. I have to say it gets them far cleaner and softer than anything else i have used. This could be a combo of the new washer and dryer and me starting to use MF specific detergents.
I am a stay at home dad during the week and after fixing our old washer and dryer for the bazillianth time. i opted to buy new ones.
LG Trom Dryer
Performance
• XL Load Capacity with NeveRust™ Stainless Steel Drum (7.3 cu.ft.)
• Sensor Dry System with Dual Humidity Sensors for Intelligent Fabric Care and Energy Efficiency
• 9 Drying Programs
• 5 Temperature Levels
• Precise Temperature Control with Variable Heat Source
• Drying Rack
• Wrinkle Care Option
• Delicate and Ultra Delicate Cycles
• Custom Program
Style and Design
• Upfront Electronic Control Panel with Trilingual Blue LCD Display (English/French/Spanish) and Dial-A-Cycle™
• Large Chrome Rimmed Door with Clear Glass
• Stackable with Matching Washer
• Porcelain Top
• Optional Matching Drawer Pedestal
Technology Benefits
• Remote Monitor Ready
• LoDecibel™ Quiet Operation
LG Trom washer
Performance
• 4.0 cu.ft. Ultra Capacity with NeveRust™ Stainless Steel Drum (IEC)
• Direct Drive Motor for the Ultimate in Durability and Reliability
• 10° TilTub™ for Easy Reach into the Rear of the Drum
• 1320 RPM Powerful Spin for Efficient Water Extraction
• SteamWash™ System for Better Washing Performance and Higher Water and Energy Efficiency
• SenseClean™ System for Intelligent Fabric Care
• SteamFresh™ Cycle
• 9 Washing Programs
• RollerJets™ and Forced Water Circulation
• Sanitary Cycle with Added Steam Option
• Delay Wash (up to 19 hours)
Style and Design
• White LED Tub Light
• Stackable with Matching Dryer
• Porcelain Top
Technology Benefits
• Highly Energy and Water Efficient
liquid tide with a scoop of oxyclean (add when it's in the wash cycle) in warm water. on the final rinse, add about 4-5oz's of vinegar (helps release any left over detergent) and dry on the lowest heat setting...
I use All (the one with no additives). If they are bad clean, I put 1/3 cup of simple green in there with the All and use an extra rense cycle.
:bow
ive been wanting those sooooo bad but the fiance wont let me buy them yet :sadpace:
The ones they have at HD are a beautiful red!
i was wondering if there is anything i can do to COMPLETELY remove everything foreign object/material from my microfibers. i have machine washed them twice w/ liquid tide and 1 cup of white vinegar and i still have pieces caught in the towels
try soaking in a bucket overnight and then try to massage it out, and then re-wash. if there aren't that many things in there, use a pair of tweezers and pick them out. if they don't come out then, toss them as it's not worth scratching anything you use them on...
Carl Johnson said:
has anyone tried this product before?
I use that, but a smaller bottle and it works fine. Just go by what the instructions say. I wash my MFs in hot water, but remember new MFs can transfer colors to other MFs, so maybe u should wash dark MFs with dark MFs and light MFs with light MFs when they're new, unless you don't mind the color changes.
I wash my microfibers with 1/2 as much liquid Tide as I normally use, extra rinse cycle and in place of fabric softener, I use a cup of white vinegar to rid of any left over detergent in the towels. No bleach.
Dry with warm, not hot.
More importantly perhaps, I fold them right out of the dryer to avoid them picking up anything on the process between the dryer to the bin.
Boil your Microfibers, seriously. Then pick them by hand. MicroRestore is great, also works for buffing pads!
I use regular liquid laundry detergent, and add in vinegar for the rinse. Helps remove polish/wax/etc vs just the dirt.
