Mequiars ScratchX / ColorX
Search around. ScratchX is used to remove fine scratches, while ColorX is a highly recommended cleaner wax that removes oxidation (similar to AIO). I use ColorX to prep my surface before topping off with 2-3 layers of Collinite.
ColorX as compared to Klasse AIO, is it easier to use? Cleaning and polishing, is it more effective than AIO? From what I have read ColorX and ScratchX work really well even applied by hand, how true is that?
I haven't used Klasse AIO before, so I can't comment on the comparison. I believe the cleaning ability is about the same, possibility slightly less. ColorX and ScratchX indeed work (relatively) well applied by hand. However, ScratchX takes a lot of good rubbing to get the scratches out.
